ALL manufacturers have a "standing" TSB against flushing anything. They do not WANT their vehicles to last! Otherwise, they would collectively be "out of a job". That is a quote I heard from a GM engineer 40 years ago.
The world of automotive reality has changed radically in those 40 years. Physics is still rock solid consistent. I had a customer who was a retired GM driveline engineer. He had a crew cab truck that I performed some work on. Under the hood were 2 homemade boxes with hoses running in and out and electric cooling fans on both. one was an ATF oil cooler and the other was an engine oil cooler. See, he knew that heat was/is the greatest enemy of fluids. He had me pull the transmission dipstick and take note that the fluid was pure pretty red and looked brand spanking new. He informed me that this fluid was original with over 90K miles on the clock and him pulling a goose neck travel camper trailer behind this truck.
Engine oil, unfortunately, has other factors that exacerbate it's demise. Keeping motor oil cool does help, but it still gets contaminated with combustion by products.
All the prattle aside, I've noted that vehicles I've owned and those which I've maintained for others over the years have benefitted more from regular maintenance intervals being adhered to AND the truly worthy additives being used.
My 2004 Truck with 165K miles on the clock certainly does better with the additives. I'll continue to flush and change fluids on it.
@Shermanbird I posted the details of a document that can be verified as a fact. Fact is different than opinion, assessment, point of view, speculation, impression or judgement. I neither endorsed nor condemn it. However, it is a fact, something that has actual existence.
I made my foray into the automotive world the summer of 1976, building fiberglass body parts for corvettes. I, like you obtained GM certification, ASE certification, Several hundred hours through GMs STG. I was part of the GM TAN (Technical Assistant Network). I was Pit Crew Chief of a race team in the 80s. I have a “I love me” book about 3 inches thick of certifications. BLA BLA BLA!
I had the opportunity to work with some wonderful engineers, mechanics etc., that had the greatest pride in what they did. Funny along the way I never heard a whim of “they don’t want a vehicle to last”. One singular fact of “physics” holds true, an internal combustion engine in a carriage put into the elements is not going to last, period.
While physics are important, chemistry is too. The TSB calls out a specific date. That tells you the chemical composition of the seals etc. changed. My challenge, go to the additive makers and ask, did they change the chemistry of their product to coexist with the new chemical composition of the seals etc?
With that said do you realize how absurd the statement
“All manufacturers have a “standing” TSB against flush anything. They don’t want their vehicles to last! Otherwise, they would be collectively “out of a job”” sounds? A disgruntled engineer with an ax to grind does not qualify, period. I find it a bit ironic I even mention, in the TSB, FCA DOES recommend “FLUSH CHEMICAL” for the coolant in the presence of sediments. I guess that part of my statement just slipped by.
Here is my experience, I do not “endorse” additives or flush chemicals as “routine” maintenance. I will
recommend using quality fluids of the type required. All oils are not equal, all transmission fluids, not equal etc etc. My 78 Camaro with an inline six had 516 thousand miles on it when it died. That car was as reliable as god. Not one additive or flush chemical was introduced. My 98 Ram, 277 thousand miles on it, not one additive or flush chemical was introduced. My 2007 Ram, 369 thousand miles on it, not one additive or flush chemical was introduced.
Here is what I will “recommend”, routine maintenance based on the individual’s driving habits. The maintenance schedule in the owner’s manual is a
guideline not a rule. The driver’s habits govern all. I will recommend and encourage the owner to learn about the maintenance and why it’s important. However, that is the owner’s choice, my "word" is not good enough and I will not become the reason why an owner does or does not make a choice to do something.
In the final analysis “you” have to answer this question, while you may “endorse” something that is contrary to a manufacture guidance, does the manufacture endorse you?
