Adding sub box and amp
cappaj1
Rochester, NY
2015 Dodge Ram Big Horn Crew
5.7L Hemi 395 HP
I have brand new fosgate 10" boxed sub and Fosgate amp for it for a Sierra I never used. I want to install it in my brand new 2015 1500 RAM Crew Big Horn. I know I will have to modify the box to fit, but, two questions:
1. Where do I run power to under the hood - if in the fuse box, which fuse, or direct to the battery?
2. The amp will take speaker level inputs - can I tie into the rear door speakers for that, and do I need to tap into both speakers? Thanks
lilzilla2008
I went to a post that came off the battery maybe for the fuse box but I'm not sure. I know it's hooked to where the power wire for the battery goes.
I ran mine (line output converter) off my rear speakers in my rcsb. I was actually told that it works just as good running both the left and right to one speaker in the back but I ran them to both sides
tigger54
