Adjusting E brake
Brl2005
I need to adjust more tension on my E brake. Does the rotor need to be removed to do this? Or is there access from behind? I looked and only saw where the cable hooks up.
Thanks, Brian
kad
Hudson Valley, NY
5.7L HEMI
There's a small rubber plug on the back of the shield that you pull out to get at the star-wheel adjuster. IIRC from last week when I was doing my brakes, it's on the top on the driver's side and on the bottom on the passenger side.
-K
PrettyMolly
If you have an automatic, just remove that overpriced parking brake setup...
That is the worst design ever... disk brakes + drum brakes on the same axle??? So you have to buy the pads for disk brakes at $30-$50, and then the stupidly overpriced shoes for the outdated drum brakes.
I have an automatic, and removed the parking brake from behind the rear rotors, and only have to worry about the brake pads now.
Black W900
Nashville, TN
Don't do this.
Reactions: kad
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
I wouldn't do that too you park that truck on a steep incline the transmission jumps out of park you are screwed.
