Aftermarket SIngle-Din Stereo
Gunnarson52
San Angelo
I have a 2013 ram 1500 tradesman. I am wanting to take the stock radio out and put in an aftermarket head unit. I have taken it out and tried 2 different stereos and they will not work. To adapt to the new stereo I have to use a harness and I have used 2 different harnesses as well. The stock stereo works fine but I am wanting to put a new one so I can hook subwoofers up. Does anyone know why the new radios will not work? Please help
DAK2
Check out Crutchfield
CtCarl
Southern Connecticut
4.7 Semi-Hemi
That's good advice. Put your truck year, make and model into their website and it'll tell you the part numbers for the harnesses to use. You may have to add a head unit to your cart and then view the cart to see what's included.
G
Gunnarson52
San Angelo
That is what I did and I bought exactly what they said I needed.
DAK2
Call Crutchfield support and they will walk you through install and setup, although their install sheet that comes with your radio should be comprehensive enough.
G
Gunnarson52
San Angelo
I have installed them before and have never had an issue. My wiring is sound I have tested the harness power with a fuse tester. The radio just wont turn on. But I know the radio works as I have tested it in another vehicle.
kurek
Northwest
I'm pretty sure I needed to install an adapter box from Maestro to get the accessory power signal from the truck. Wasn't cheap exactly but I like no-nonsense fixes and I've long since forgotten spending the money.
G
Gunnarson52
San Angelo
Where did you get it and how did you install it?
kurek
Northwest
I know I got it from Crutchfield, but it was almost 5 years ago so I don't remember if there was anything special about installing it.
If you're not in a hurry I'm going to be opening my dash up asap as soon as the upfitter buttons I ordered arrive, to install those and a trailer brake controller. I can take photos for you of how the radio's hooked up at that time.
G
Gunnarson52
San Angelo
Thank you. I figured it out When you said that you had an adapter to use. It got me thinking that when I got the harness it came with one but my friend said I didn't need it and he has done these alot. I decided to try it and it made the stereo work Thank you so much for the help!
