Air bag setup for load leveling?
Dr. Righteous
Jamestown TN
Just recently hauled a '79 Ramcharger bought for a restoration project up from Florida. Because of the size of the truck it was kind of hard to get it exactly balanced on the trailer. So I ended up with too much weight on the hitch and the rear had a significant squat. So the trip back was a rough ride since it soaked up every bump on rough patches of interstate.
Was thinking an air bag system to for the rear would really help in these situations. But this is something I really don't know much about. This is only a 1500 Express with a towing package. Any recommendations?
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Lot's of options for air bags. I like to shop on etrailer.com for my stuff. Reasonably priced & will answer any questions you might have about their products & applications. There are many vendors on ebay & Amazon as well. As stated above you can get a set up fairly cheap & average install times around 2-4 hours.
Jamestown TN. huh? I have in-laws that live just outside of town.
Dr. Righteous
Dr. Righteous
Jamestown TN
Yeah, Jamestown is far enough off the beaten path it still has a small town "Andy Griffith Mayberry" feel to it.
Elevations is 1719 ft so summers are mild, low humidity. A hot day is a high of 86* with 40% humidity. Winters can be snowy but accumulation is usually not more than 3-4" for a "big snow". It will melt off in a few days. Below freezing weather is only in short term. Highs in the winter is is usually 40s and 50s. Fentess Co. is the last dry county in TN. No bars. No alcohol served in restaurants. Crime is almost unheard of. If you enter the local hardware store you are greeted with a smile and a handshake for unfamiliar faces. The clerks know every nut and bolt in the store so getting what you need is fast and friendly. Here these are Church going folk. On Sundays the activity is people making their way too and from Church. Sundays are of peace and quiet and the forgotten restfulness of a true Sabbath.
Toddbigboytruck
Ontario
Hi all got a super question would air bags help while towing TT And a WDH help with fuel efficiency
yes and sorta yes..
You use the airbags in conjunction with a WDH to firm up the rear end. The airbags act like helper or extra capacity springs when you need them yet let you retain the factory ride when unloaded. When I tow the 28' I'll put 14 psi in the bags and with the WDH it levels me off and have a good front to rear weight distribution.
A WDH is for vehicle stability, it may help from an efficiency standpoint as you won't be fighting the trailer.
Towing a trailer is like having a parachute deployed behind you. Unless you put something on the truck to direct air over the trailer, not much is going to help other than how fast your traveling.
Toddbigboytruck
Ontario
yes and sorta yes..
Thank you. What are you getting on mpg or L/100. My tt is 5500lbs. Full load. We are planing on driving back to Florida this time keys next December last time it cost $1000 round trip. At best I have 26L / 100km or 9mpg
your welcome. It won't be a very relevant comparison, with my EcoDiesel towing the 28' (a good 8K lbs) I get just about 15 mpg.
Interesting when I tow a 24' enclosed car hauler empty(3K lbs) the fuel economy is in the 16s mpgs. Towing the same trailer I high winds it dropped to 13 mpgs.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Timber Grove air bags are real nice for our 1500s, easy install and top quality parts.
There is also 1211 TuffTruck replacement rear coils that work well.
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
When towing my 9,000 pound 30 foot Airstream I get between 10.5 and high 11's mpg. The airstream does sit a bit lower than most travel trailers and is also rounded more on the front, so you are not pushing as much air and mileage is usually a bit better. Also, I rarely exceed 60 mph.
Toddbigboytruck
Ontario
Yes we are hopping out next and last tt will be a fly cloud bunkhouse it would s in my five year plan. Do you use the on-board brake contrôlée I have read a lot on this forum about people that have issues with the factory electrical brand control. I have no issues with my on-board brake controller.
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
Yes, I use the on-board brake controller. I love it, it modulates the brakes very well. Works much better than the aftermarket, Tekonsha, unit I had previously. There are probably better ones these days, but the OEM one works great for me.
And I use Tow/Haul mode whenever towing or loaded.
Toddbigboytruck
Ontario
Thank you. I also use tow/Haul as well
prp9391
Marysville, WA
6.7 Diesel
I just bought the 2019 3500 Laramie Longhorn and it did not come with the Auto Self-leveling feature. Does anyone know if the Dealer will install after market or how to get the OEM Auto-Leveling kit added? Any idea on costs?
Just curious so when I call my local dealer and ask I would like to have a second opinion...
Thanks!
Chances are you won't be able to get the OEM set up installed but Airlift has helper airbags for your truck. They also list installing dealers:
https://www.airliftcompany.com
My buddy uses an Airlift WirelessOne compressor with rear helper airbags on his 2500 which he hauls a fiver with. It works real nice for adjusting the ride while traveling.
prp9391
Marysville, WA
6.7 Diesel
Crash68
Thanks, I kinda figured that would be the case and I also saw the Airlift WireOne setup. Looks pretty sweet and with my 2-post should be easy to install...
Thanks!
@prp9391 it took my buddy and me a couple of hours to put his airbags and WirelessOne set up in, that was with having to make a mounting bracket for the compressor. His is the Gen1 compressor, the Gen2 version can come with a mounting bracket and has Bluetooth. We weren't working very hard either, typical working on a vehicle and drinking beer routine...lol
Lurchav8r
