Air Lift Helper Bags with McGaughy's 2" rear?
dkmesa
I am looking at McGaughys rear drop springs for my 2014 CCSB 2wd (2" part num 44055). Is anyone running Air Lift 60818 with these springs?
Has anyone cut factory rear springs and installed helper bags?
I'm trying to determine if Durango helper bags are required for a mild drop (1.5-2") or if Ram bags will still fit.
Thanks for any input.
Statcher1
Kentucky
I didn't run them in my 2" drop springs. But I wish I had. I made sure to run them once I went to a 4" drop. And the airlift1000 bags will probably be cheaper and work just as good for you.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Go with the Durango bags. The Ram bags will work, but they bulge a bit on the 2" drop coils.
D
dkmesa
Have you encountered customers with this setup? I wasn't sure if the Durango bags would be tall enough to do much of anything. Thanks.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Yes. I even ran this setup on my own 2011 crew cab before going with a full 2/3 drop. They still work as they should and fit in the coil nicely.
The stock height Ram bags are too stuffed in that 2" drop coil, so they bulge out the sides of the coil.
D
dkmesa
Moe, do you know the height of the spacers with the 60818 Ram kit? Would trimming the height of those be an option?
D
dkmesa
Thanks for the info. Sounds like I will give the Durango bags a try.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The Spacer on the Ram kit is only 1/2" thick.
D
dkmesa
Cool, ruling that out. Thanks
audio1der
Airdrie, Alberta
FWIW I spoke with Airlift and based on my 2" shorter springs height/diameter they recommended a kit from a Land Rover. I wasn't impressed with how short the bags were, so I went back to bags for stock height and have never had an issue.
TwistedJake
NW Oregon
2014 Ram 1500
Did you just order the complete Durango kit? Part # 60824
Or do you have to order the Ram kit and swap out the bags? Just didn't know if the spacers or anything else involved were different between Ram and Durango.
ChloeBrooks
