Is there a way to set the default air ride suspension mode to entry mode when the truck is turned off? Seems to me that it would make sense the truck would automatically go into entry/exit mode when turned off? Right now when turned off I think it stays at whatever height the truck was last operated at but not sure.
I'm glad I got air ride suspension - for me the ride is near perfection.
There's no factory setting to do that. And you're right, the truck will stay at whatever ride height you were at before shutting the truck off. I'm frequently sore from work/hockey beer league, so what I do is : use the key fob to lower the truck as I'm walking up to it. I usually remote start the engine first, as occasionally the ride height change will be canceled due to "low voltage." Ram had a recall to address that, and I had it done, but my truck still doesn't like changing ride heights sometimes without the engine running.
I suspect that Ram didn't add an automatic lowering feature for a couple reasons : first being the battery drain. The pump motor draws a decent amount of power, and without the engine's alternator continuously re-charging the battery while the engine is running, the battery's life will be significantly reduced (obviously being a huge issue to the owners).
Second being; if you're parked over something that the truck might lower itself onto, causing damage to either the undercarriage and/or bumpers/sidesteps/rockers. This is also certainly why it wont let you lower the truck if the doors are open. It's requiring operator input, so in a sense, the truck doesn't do something "stupid" on its own. If the truck automatically lowers onto something, and damages itself - that's on Ram. If the operator lowers the truck onto something, and damages itself, it's on the operator.
