Air suspension issues
Travis1027
I have a problem with the air suspension, I know this issue has been addressed plenty of times already but mine seems to be unique or maybe im just being dumb can certainly use some help.
The problem is the pump isn't turning on and its fully deflated.
All fuses are good, swapped relays still nothing. Also remover the battery and tried resetting the air control holding the two buttons. I put the airride setting into wheel alainment mode and pulled the fuse to test if im getting power to the fuse and lo and behold there's no power to the fuse.
Would this be a problem with the ASCM?
Luis LeFort
Las Vegas
5.3 HEMI eTorque
I had a similar issue with my old truck, and I thought it was the pump. I even bought a replacement pump. I may end up being my rear airbags. They had pin holes when the rubber started cracking, and it let the air out to the point where the pump would just quit because it’s not filling them up. Or you can remove one of the rear airbags. They’re very easy to remove, fill it up with a little bit of air, and spray with some water with soap, and you’ll see if your bag has pinholes, and that’s what’s causing your pump to quit or maybe even ruin it.
olyelr
Kewadin MI
Hes not getting power to the pump.
KMac11
New Hampshire
Hemi 6.1
Incompetence at Stealership ! Air Suspension - 2016 Ram Laramie . 6 months ago I brought my truck in for the dreaded lean , they saw it , acknowledged it and said since there no code there’s nothing to repair . Wait for a code , bring it back !
6 weeks ago the code came up , all that time overworking the compressor . After them having it for 6 weeks, with excuses galore , $ 5000 + into
Repairing and replacing almost every component , I unknowingly left with a broken truck , the suspension does not rise up or down, and just a minute ago , I get the warning to service suspension immediately! Oh I forgot to mention they dented my truck then tried to cover it ! Lawsuit is forthcoming!
