Air suspension Wires / position in wiring block
Rob Nicolodi
Virginia
5.7L
My 2020 Ram 1500 Laramie did not come with air suspension and I am not looking at adding it. What I do want to do is change out the controller for that has Traction control, tow/haul, and rear/front parking assist to include the Air ride switch as well. I want to then wire that switch to operate my train horn. I currently have the train horn wired to a button that is mounted to an aluminum plate that I taped up to make it less obvious. But to have it on that air ride switch will make it better looking and less conspicuous. I have no desire to connect the train horn to the factor horn. Any help identifying which wire / port in the wiring harness I need to connect to would be awesome. Thank you
ameer73
