Airbag Light
04RAM_3
CA
I recently pulled my 04 dash rebuilt my HVAC. When I put it all back together my airbag light is on. Any ideas where I should start looking so I can fix it?
jws123
nj
check the connector at the passenger side kick pane also scan for airbag codes.
04RAM_3
04RAM_3
CA
I will check the connectors there. Thank you. I have MX+ to scan for codes. It didn't pick up any. How do you scan for airbag codes?
04RAM_3
04RAM_3
CA
I checked the fuses, good. I pulled the radio bezzle and checked the connection, good. I disconnected the battery. I heard that you're supposed to pull the positive terminal and hold it to the negative for a few seconds to reset the bag system, so I tried that. Reconnected the battery and no difference. I'm not sure what I'm looking for in the passenger side kick panel, so I'll check everything here in few minutes. Anything else to check you guys can think of?
How do I run codes on the airbag system?
