Alarm
Greenham
Raleigh NC
This is kind of a dumb question. How do I know if the alarm is set? I see no evidence aside from locking the door via the remote?
Fast69Mopar
If your truck came equipped from the factory with the standard RKE there is nothing to indicate that the alarm is set. Its not really an alarm in my book. The only thing that will set the horn off is if you use the door handles. If you break a window or open the hood or tailgate nothing happens. The only thing that is like an alarm is the SKIM which is the Sentry Key Immobilizer. If you do not have the FOB in the ignition or in the vehicle for push-to-start then the engine will not start.
NapaRam
Napa CA
Hemi 5.7 L
I used Alpha OBD to turn on the VTA (Vehicle Theft Alarm) as it's called and when I did a small red LED now flashes in the 7" EVIC cluster so I imagine you should see this. Are you sure the truck with this enabled with your VIN?
Fast69Mopar
This is what I forgot to mention. With the VTA enabled either by the WiTech or the through AlfaOBD the small, red SKIM lamp in the EVIC will flash red.
Greenham
Greenham
Raleigh NC
The sticker had a few security items listed.
1. Remote keyless entry with all secure
2. Sentry key theft deterrent system
3. Sport package 26L with
I will look through alpha OBD
- remote start and security alarm system
- security alarm
NapaRam
Napa CA
Hemi 5.7 L
- security alarm
FYiI you can't use alpha to enable remote start but you can enable the VTA, Lighting options. Cargo Camera, "Global Window Down" and other features. Remote start requires additional hardware if not present when purchased
