Alfaobd and Custom Bed Lights
DoughRat19
Massachusetts
2019 Classic
I finished up my bed light install today. My 2019 Classic did not come with bed lights or the wiring and I didn’t feel like spending $150 on an OEM kit. I bought a $23 LED light strip kit off Amazon and $7 wire conduit to protect the wiring under the truck. I had some shrink wrap, wiring, zip ties, and terminals already.
First thing I did was cut up the LED kit. I layed the lights out in the bed, fished the wiring through the factory location for the bed lights and then wired the two strips together. Added some of my wiring, wrapped everything in conduit and ran all the wiring to the engine bay. Grounded the ground wire to a body ground near the fuse box and tan the second wire into the cab and pinned it to the C1/A Pin 5 location for the bed lights. Turned them on with Alfaobd and they work great.
Only thing I’m missing is an on/off switch in the bed of the truck but I’m ok with that. The factory location for that was bed lined over anyway. Lights turn on/off with unlock/lock as well as when you use the cargo light switch in the cab just like the factory lights.
Hevel
USA
Pentastar V6
Looks pretty clean. Any concern about the adhesive on the LED strip peeling over time?
DoughRat19
DoughRat19
Massachusetts
2019 Classic
yeah, the backing that came on the strips isn’t great. I ended up putting some 3M tape over it and used that to stick them to the bed. With the bed liner the backing on the strips didn’t like it much. The 3M made a big difference, could tell right away it was going to stick well.
Hevel
USA
Pentastar V6
Good call on the 3M tape. I'm going to try to do something like this:
Looks like he used the 3M tape too.
LoadedExpressRam
Gulfport, MS
You mind giving me an idea where this pin is? Im guessing the hardest to reach location. Appreciate the help.
Hevel
USA
Pentastar V6
Would love to help you out, but I still haven't gotten around to the mod :p
Mudd_jumper
Lenox, MI US
Looks clean, I am looking to do something similar! I am in and out of my bed way to much!
DoughRat19
DoughRat19
Massachusetts
2019 Classic
I actually just recently redid my setup. Was kicking myself for not adding the factory switch in the back the first time.
Mudd_jumper
Lenox, MI US
I like that idea, is a great addition. I have a 14 so adding the stock lights is not an option since they did not have any option then that I am aware of. I was thinking why cant I run a wire from the cargo lights and so when I turn it on the bed lights will come on. Also like you did put a switch in. How did you wire that to get it to go both ways?
DoughRat19
DoughRat19
Massachusetts
2019 Classic
The switch was an added option starting in 2018 I believe. Both the switch and lights wire back to the BCM. You definitely should be able to get something wired up taping into the cargo lights.
Mudd_jumper
Lenox, MI US
Yes I think that will work well, I will look for like a three way switch to turn the light on from the bed as an option too.
Steve58
