Thank you both very much, I'll be doing this soon as the pins arrive, they are scheduled to arrive today or Monday. I do have my 4 digit pin so I'm ok there.
I'm not sure what an RF hub reboot is or how to do it. I went into the RF hub with Alfa and clicked on the remote start antenna test and it showed "FAILED" . Can I please get an education here of what I have to enable to have a working remote start besides grounding #11, enabling the hood lock switch setting, VTA just for an extra plus?
My log shows,
Remote Start Present: Yes
CBC I/O Hood Ajar Switch Input Present: Set
VTA Warning LED Output Present: Set
VTA Ajar Monitoring: Set
If I need to pull the upholstery that overs the RF hub to see the pn# and if it has an antenna, I will.
Any help is greatly appreciated
L2B......when you reset the RFH hub you are making the RFH hub re-read your BCM. When it does this the RFH hub looks for changes made in the BCM and then makes changes to the hub so that the sittings mirror each other. Right now your RFH hub does not mirror your BCM settings for the remote start. So you need to do that "reset" procedure.
To reset the RFH hub, after you open the Alpha program instead of going to BCM Module that is on the second line under the line in the program where you will have "1500 Ram":
-use the drop down to go to "RADIO FREQUENCY HUB (RFH)" (instead of the "BCM" setting you usually go to)
-then for SELECT CONTROL UNIT you pick" RADIO FREQUENCY HUB"
-connect to the HUB
-you will see a warning screen and at the top you will also see SELECT PROCEDURE TO START
-select" RF-HUB RESET/REPLACE"
-next screen you will be asked to enter your 4 digit PIN, enter it
-press start
-when its finished you will get a PROCEDURE COMPLETE
-back out of the program
