AlfaOBD
chum
US
ecodiesel
Lots of things hahaha, read the first page. There's a list.
Sent from my SM-G950U using Tapatalk
jordanlbrt
US
2013 2500 mega cab
Success!!! upgraded to the power folding tow mirrors. ALFAOBD is the s--T
How did you accomplish this. I have a 2013 2500 Laramie longhorn package, but they didn't offer power fold that year from my understanding. Is there harnesses or add ons that make this possible for reasonable price, etc etc. Thanks!
chum
US
ecodiesel
You'll need to get the door modules, master switch and mirrors(I went with 1aauto). Hardest things is finding the correct modules to match your year. Oh and use the alfaobd to active it.
JB1
Houston, Texas
I have a 2016 Big horn 1500....what are some of the things I could do if I bought this?
  • Activate daytime running lights
  • Add bed lights
  • Add led chmsl cargo light with camera
  • Add vehicle alarm
  • Add trailer brakes
  • Set lights to LED
  • Enable fogs to stay on when you turn on brights
The list goes on and on just kinda depends what your plans are
GMcD
South Carolina
  • Add bed lights
  • Add vehicle alarm
  • Set lights to LED
Wow, definitely sounds like I could use it!
rmoyer72
Allentown
The only issue with this is that you wont get any light out errors if any of the tail lights are out.
rmoyer72, do you have resistors on the tail lights? Which lights did you swap to?
I found that when you set lights as LED you need to remove the resistors. So if the lights have built in resistors you shouldn't have to swap to the LED setting.
Yes it has resistors. Can’t remember the brand, but they were cheap one off of amazon. I did change everything back to non led, but I am still getting the same error. I am going to try and remove the resistor and see if that works or if it makes it worse.
scott_intx
San Antonio
Anyone used Alfa to correct for a 26 to 32 gal tank conversion? I was thinking about changing the "fuel capacity" option.
Jimmy07
If you want the 32 gallon tank to read like it would if it came from the factory, then you don’t need to do anything...
On a serious note, I think that’s what everyone that already has a 32 gallon tank is trying to figure out, since it reads as if it has the 26 gallon tank.
scott_intx
San Antonio
Nothing like your truck telling you it’s completely empty with 5 gallons left.
Hawaii_Built
Hawaii
ecodiesel
Has anyone attempted to connect a front mounted camera with this as of yet?
Jendsley06
Southern Illinois
In China, our trucks are imported by private dealers with only a small sales volume. They even only know that this car has four wheels. We have set up a small car owners group, and only a few people will modify the off-road functions such as chassis and suspension. No one is studying electronic systems. I study alfa is just a personal hobby, if its too complicated, i can only give up. . . The fourth point I said was about the four-digit password of the truck this forum mentioned before. I can't get this. God, I hope that Google's translation can be great. The Chinese grammar is really complicated.
fengfengfeng .I just read on another forum that there is a new ap available in the Android play store called "Chrysler PIN Puller" from a developer XLocksmith. Maybe if you can get this ap over there so ehow it will help get the PIN. I don't think it is guaranteed to work on vehicles newer than about 16 if I remember from what I saw when I looked it up. Just a little info to do with as you can
Reactions: JB1
kad
Hudson Valley, NY
5.7L HEMI
Yes I believe @kad and @Ghost_RAM and a few others did that
Ghost has his running, I'm still working on mine, but my delay is mounting the camera, I've got the option on the radio running. What we've done is simply plug it into the input for the Cargo Camera and turn on the input with Alpha.
The setting you want is:
Vehicle Config 1:
CHMSL camera: Set
-K
kad
Hudson Valley, NY
5.7L HEMI
New Android version dropped last night, 2.1.6.2. The official description is "More before PowerNet suppot and various fixes". Vehicle Config 4 is still missing, at least on a quick check while NOT connected to the truck.
-K
kad
Hudson Valley, NY
5.7L HEMI
There's a fuel capacity setting
Vehicle Config 3:
Fuel Capacity: 98 Liters
And a set of calibration values:
Cluster Configuration:
Fuel Tank Calibration, Full: 91%
Fuel Tank Calibration, Empty: 2%
Fuel Tank Calibration, LFW: 8%
I think I recall someone recently saying that they'd changed them. I don't recall the results though.
-K
Ghost_RAM
Ghost_RAM
VA
-K
A couple of us noticed this yesterday when I was going through the settings starting to update the known working. Not really sure what is going on? Hopefully there will be a correct. I was going to email him today after I look into a couple other issues I noticed.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Vehicle Config 1:
CHMSL camera: Set
-K
Here's the hardware install posts from the 13 ram I had that was enabled via the old Customtronix jailbreak vs cargo cam input. You'd just need a female RCA pigtail fire the radio to get the video hooked up.
- Post 1165/1166: My 13Ram Front cam install.
M² Mods.
scott_intx
San Antonio
Vehicle Config 3:
-K
This is the factory 26gal settings, correct?
sigsauerP938
