AlfaOBD
1500ram12
5.9L Cummins
Hello all,
A lot of great information on this huge thread but there are a few questions I have.
1. I have stock projectors and turned on the DRLs. The DRLs are working just fine but the option to turn them off on the radio is not there. Not a huge deal, I'd still rather have the DRLs working but having the option to turn them off real quick would be a nice bonus. I have seen on this thread that some other people have had this same issue and that it can just take a few cycles of running for it to turn on. Is this true? I have gone to the post on this thread with all the functions that need to be changed and double checked mine. They are all changed correctly.
2. Does anybody know if you can make the radio go to the navigation map by default rather than have to go to nav and then hit map?
3. Is there a way to display the gear select all the time or no? I did find a setting under ECM Config 4 - Gear Display and tried it but it did not do anything. Is there maybe another setting I have to change to get this to work?
TIA!
Some trucks the CSM setting for drl's can take 24-48 hour's to show for some reason. Disconnecting the battery may help it show up faster.
I doubt there is a way to set nav as the default screen without using a 3rd party add on device.
I don't think that gear display works on our trucks. I've tried it and haven't seen anywhere it could be displayed
2018 2500 6.4L Tradesman
Tucker
Evergreen, Colorado
3.0 Ecodiesel
thanks for the reply! I tried the gear select as well and it didn't do anything for me either!
JMod45
TX
6.7 Diesel
Hello all,
TIA!
For the DRL, "ECUConfig 3-DRL customer setting enable/disable"
that should give you the check box in the settings menu under lights.
2 and 3, no idea
Richmond2000
2 and 3, no idea
also DRL type set to optional NOT EC OR Canada
and check country code for USA and NOT Canada as I believe those disable the DRL disable option on settings menu
dracman
canada
2011 ram 1500 reg cab.dads ol truck
i just put mine in too but wont change the mileage.it worked for drive hours and idel hours .im lost lol
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Alfaobd one in play store
Sorry I didn't make my post clearer @Kenepo17ram . What is the app version of Alfaobd you used to make your changes to your 7" cluster. Some others here have reported some issues with either hours or mileage when trying to make their changes. I believe the most recent update is 2.1.7.6 released 10/7/19. Is that the update version of Alfaobd you used with no issues or something different?
Kenepo17ram
Brooksville, FL
Sorry I didn't make my clearer @Kenepo17ram . What is the app version of Alfaobd you used to make your changes to your 7" cluster. Some others here have reported some issues with either hours or mileage when trying to make their changes. I believe the most recent update is 2.1.7.6 released 10/7/19. Is that the update version of Alfaobd you used with no issues or something different?
Yes thats the version im using
Rick Jones
New Jersey
I did mine yesterday too. Took 3 hours to get the odometer to change. I'm using the windows version of Alfa OBD. I increased my Interface Timeout, Request Interbyte and Iterrequest time. Settings that finally worked: Int Timeout: 300 ms / Request Interbyte 10 ms / Interrequest time 200 ms. I was able to change my idle hours and total engine life but that took several tries as well to get it to finally take. Just keep trying and slowly increase the above values until it takes.
I wasn't going to do this upgrade until later in my trucks life but got a deal I could not refuse for the cluster through a mutual connection. Price was way below what everyone was selling them for.
FYI - This was a cluster from a 2018 1500. Installed into my 2019 Classic.
Rick Jones
New Jersey
Question when programming the Premium Cluster has anyone over wrote the VIN with theirs? Is this necessary? Is it recommended?
chri5k
USA
Diesel
I didn't. I suppose there could be an issue around mileage accuracy if someone read the cluster VIN and it did not match the truck. Like wow this 2016 only has 5263 miles, that is low mileage!
dracman
canada
ive been trying every day like i said drive hours and iadel hours was done fast.have no clue why milage wont take.cluster is out of 2017 sport going in 2017 express
dracman
canada
what do ya mean by Interface Timeout, Request Interbyte lol
Kenepo17ram
Brooksville, FL
I used a 2015 cluster and all work right away
Sent from my GM1915 using Tapatalk
Reticle918
