AlfaOBD
Devin B
Pennsylvania
6.7L cummins Diesel
Hey guys I’m having a issue trying to program keys for my 14 Ram 2500 6.7L cummins before I program the remote start however I fallowed the instructions and it’s giving me this message(picture below) and now I have no keys that work and all and I need my truck tomorrow please help !!!!!!!!
TylerC
Alberta, Canada
I am in the same boat:-( . Im trying to set up the keyless entry etc with a new rf hub and program keys. I am fortunate enough to have the key start and can undo the settings and swap my original hub back in and start the truck.
Curious to see what the response is...
Jimmy07 was looking at my bcm files to see if he could sort out why it won't take... havent heard back yet.
Good luck
Sent from my SM-N975W using Tapatalk
RAMMIN_TIME
A little walk through of how to program FOBIKs
First turn you truck on to accessory.(I always do this to connect to the RF Hub)
Select Radio frequency hub(RFH)
In the drop down select Radio frequency hub(this is the only option to select here)
Connect to the RF Hub
Once you’re connected. Locate the Car with the hood up on the bottom right hand corner. Click on it
Click on the drop down menu. Almost all the way at the bottom select - Program Ignition FOBIKs Baseline system
At this point turn your key to the Lock Position(turn the truck off) and remove the key from the ignition
Place the FOBIK(Key) you’re wanting to program in the ignition and leave it in the off position
Enter you 4 digit pin provided by your local dealership
Click Start. Your screen should look something like this!
Once the process is complete you will see Procesure complete in blue. Please note the above dialogue box will say “FOBIK successfully paired” I think lol
If a key is already Paired to your truck. You will get the Failure error. “Failure FOBIK already learned”
Now start you truck up to make sure it was successfully paired!
2018 Black Pearl Ram 1500
LED Tail Lights, Black Quad Halogens with LED conversion, LED Black 3rd Break Light, Blacked Out Emblems, Rims & Grill, 8.4 UAQ conversion!
Worked great! Thanks for the write up. I got this key off of Amazon for about $18.
SRich2015
USA
Wonder why we’re getting the message! Went thru the steps above exactly but still a no go!!
RAMMIN_TIME
Could it be one of the other FOBIK selections?
RAMMIN_TIME
Yeah that is what I was referring to. I wonder if it is option related. I was successful with new key today using baseline. I do not have any of the remote start option or the keyless fob option. It’s just the plain 3 button fob.
RAMMIN_TIME
RAMMIN_TIME
What the difference between baseline system and highline system? Is that what you mean?
gapi
Georgia
HEMI 5.7
Finally a search function in car configuration change.
Administrator
Does Alfaobd have a way to change the aspect view?
The view on the radio is straight out of the camera, there is no way to change that.
If the camera wasn't aimed correct you would have to change the camera.
You say change the aspect view? Aspect Ratio is the height x width of picture. If you wanted a different perspective you would have to relocate the camera or use a different one.
No Tyme
Bryan, Ohio
Going to post this since my eyes are under strain for reading the first 20 some pages. I want to set my Fog lights as DRL's and found these settings. I question if these are the final setting to work or if there are any changes to this set up.
Here's what seems to work best:
DRL Configuration: (Set to Optional DRL)
DRL Dropout Enable: Set (No Change)
DRL Lamp Location: Dedicated (No Change)
DRL Lamp location: Select high beam, low beam, fog lamp, turn signal, etc
LED Dedicated DRL Present: Set (No Change)
Right Dedicated DRL Lamp Output Present: Set (No Change)
Left Dedicated DRL Lamps Output Present: Set (No Change)
DRL customer setting enable/disable: Not Set (Change to SET)
Daytime Running Lights CSM (sets the CSM) Select “yes”
Left Side DRL Voltage Target: 7.4 V (No Change)
Right Side DRL Voltage Target: 7.4 V (No Change)
Dedicated DRL Lamps Open Circuit DTC Enable: Not set (No Change)
This would be for my 19 Big Horn Classic
Garou78
Hemi5.7
Fam i need help programing my keyfobs using alfaobd!! Can younguys helpmme
Please.
Garou78
Hemi5.7
I cant get it to work i have done and tried many thimgs already and just cant get it to work
Garou78
Hemi5.7
To answer my own question, it turned out to be bad quality key fobs. With better quality fobs and help from Alexey it all went well. Realy a 5 minute job. Thanks Alexey!
Man i was thinking that i fcking things up!!! So i have the same issues....so i guess i need to get new keyfobs!!! Can u hook me up with your seller please. Thans in advance
Yazen
Columbia Missouri
STecoD and I installed our Cargo Cams today. His truck is a Crew Cab with solid back window. My truck is a Quad Cab and I have installed the factory power sliding window. His truck was much easier to install the harness because there is more access to the headliner with the regular window. The power sliding window has a trim ledge that made it much harder to fish the harness through. That being said the install was strait forward and as usual the harness Deer Guy (M2mods) fit perfect and looks factory. There is a small adaptor plug that connects to the the two connectors on the light. One connects to the factory truck connector and the other connects to the main harness and runs across the headliner and down to the connector in the drivers side C pillar where two wires are pinned in the #5 and #6 slot. Then there are three more wires that run to the radio connector and are inserted in pin# 24 #25 and #26 and you are done. Five wires! A couple of notes.
From what I understand the 1500 trucks need the three wires to be connected to actual radio connector. The 2500 and 3500 trucks do not. There are a few different wiring options depending on your truck so make sure you give Mike your Vin# and all your info if you order a harness so he can determine the best place to access the connectors. I have pictures and more details for those interested but don't want to clog up this thread. 0b1fec41e0c505a76f194cb35d667145.jpga0462260ebc41bedf58642e0b50bbea9.jpg4a93fb1e5b4f8af3d37bc2a45b75c48c.jpg204166dc47abb7ec35328ab08bdfdd5b.jpgc9a9192fa9bafba545b97a2a30a64eae.jpg
Can you please share links to the cam and harness needed to install it?
Thank you
Yazen
Columbia Missouri
Just chiming in to say thanks to everyone here. I saw this thread, and have now read completely through it. Purchased the app and mx+ and managed to change a few things with out completely borking my truck. So far, global down, DRLs set to high beams, DRL drop out off, changed headlights to LEDs and killed the annoying seat belt chime. Soon enough will be changing the rest of the exterior lights over to LEDs. Thanks guys.
Which setting for the annoying seat belt chime?
Thank you
