Alignment when switching wheel/tires
mike905
2016 Ram Sport
5.7L
If I were to buy a set of wheels and tires for summer (bigger size), and use stock set for winter would I need an alignment and balancing every time I swap between the two sets? Or could I just swap them out myself at home?
Ricks Ram
The alignment on your truck will not change when you switch wheels. If your tires are balanced correctly they will not need to be rebalanced. You can change them yourself at home with no issues.
