Alignment
Jamz3333
I have a 2 wheel drive 2002 ram 1500 and my tires are wearing on the inside and I was wondering if someone could tell me how to check the alignment and adjust if needed. I don't want to have to take it to a shop if I don't have to. Thanks!
wingnut
Da Thumb
5.9 gas
Inside wear can be caused by incorrect camber, or toe. Ram front-ends are not the sturdiest. I suggest you watch some youtube videos about how to check ball-joints, or tie-rod ends. That will give you some info to take to the shop if you are not mechanically inclined. A little knowledge will help you so they don't take advantage of you.
