All Repair Parts @ Employee Cost!
Units
Ms
2023 Bighorn
6.7l Cummins
Hi,
Honestly I was not aware the door modules controlled these circuits. Have you tried looking for a related sales code or feature within Alpha to activate them first?
-Benny
Well maybe I was mistaken, from reading around I thought the turn signal/puddle lamps, along with heated mirrors were all intertwined with power folding mirrors - of which I do not have - required a certain door module. I guess I’ll give alpha a whirl and see what happens. Thanks.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
Looking for stock/OEM shocks, I actually like the originals and all I wanna do is get set up so I can purchase when I feel like they are going bad enough
VIN 1C6RR7FG7HS829942
Looking for exact part numbers please and or links, THANKS MUCH.
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi Joel,
Sure here are links to them
Availability is good at the moment. I will send you a code you can use when your ready.
- Benny
SixAddict
Phoenix, AZ.
2019 Ram 1500 Laramie
Hi Benny, I also am looking for OEM shocks. it appears the above part numbers will fit my 2019 2WD Ram 1500 DT.
How long does the front coil spring last? I’m at 43k and wondering if I should just replace shock or shock and spring.
Thanks.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Thanks.
Hi,
There are a few options, I will need your VIN please
Thanks,
- Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
SixAddict
Phoenix, AZ.
Benny, would you replace springs also? Truck has 43k on it and seems to ride almost fine.
Thanks, will contact you shortly.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
No, Under standard use springs should go to 100k no problem.
Please let me know if you have any other questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
1C6SRFHT3PN602248
Thanks,
Here are links to them
I will send a code you can use,
- Benny
Fritter
Marine Corps
So Cal
The rear area of my 2017 Ram 1500 CC cabin is damp and it appears that I'm in need of 2 bodyside aperture exhauster's. Part number I've been finding online is 68323649AB.
Treburkulosis
Glorified Car Washer
Haslet, TX
I need a power driver seat motor for a 2012 Dodge Ram 1500 Lonestar. Do you happen to have one? Its cloth.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi,
It looks like youll need a complete adjuster that includes the motors but can you send your VIN as there are a few options.
- Benny
Dannnn
Can you link me to a 5149062AB Oil Pressure Sending Unit for a 2014 Power Wagon?
VIN: 3C6TR5FJ8EG291163
Thanks!
Dan
bbramer0820
