Went to remote start my truck, no noise or any feedback (2-way remote). So i walk outside to manually start it, no lights flashing when i hit unlock... door wont unlock. I manually unlock it with the key inside the fob, and when i look at the guages, the small red "security?" light is on. I think its the security light, small red led diode looking bulb, bottom right of gauges.
Ok let me break down the key points real quick.
- 2012 Ram 5.7L Hemi
- Battery is 3-4 months old and is a premium battery (forget the brand but it was $270 before my coupon)
- Last drove it 4 days ago
- Remote start installed at Best Buy in December, not a single issue after install... not sure if its related
- Tried to remote start, nothing
- Had to manually open door with key
- No headlight flash or any door chime
- Gauges has small red light lit up for 1/2 a second when i opened door
- Tried to start truck, wouldnt start, key stuck in ignition. Wont turn to off position
- I can not shift the truck out of park into neutral or any gear. Stuck in park.
- I unhooked my Pedal Commander, no fix.
- I unhooked the battery (+ and -) for 10 minutes, did nothing at all
So now im stumped. Key still stuck in my truck, cant shift into any gear. No lights, no radio, no chimes, nothing. Its like the truck is in hibernation mode, or lock down mode. Not sure what to do.
I had an aftermarket remote installed in December. The remote start is the Compustar 4905S kit with 2-way remote (expensive kit). Like i said, ive had zero issues with the remote start since its install.
I have no clue what to even try to do next. I think im going to have to have it towed to a dealer because i am uncomfortable letting my truck sit out front with a key stuck inside. If i cant figure it out in the next couple hours im going to have to have it towed, i am not going to let it sit overnight with a key in it.
Does anyone know what happened or have a similar incident?
