Ram1958
Try moving your shifter. It is possible it's not in correct place and will prevent key from being released. If you have shift know instead of column shift there may be a problem there.
Well when ever a dodge truck has electrical problems. I disconnect the battery, loosen the ground on the body and engine, and clean that connection, and i get power back. Been a common problem with dodge for more years than I can remember, and I'm old. Continuity checks work and easy to do. And is always the first place to start.Its not the fob or the ignition. The entire truck is shut down, no power, nothing works, wont even shift out of park. Absolutely no power to anything in the truck.
The exact same thing happened to me this winter. 2012 Ram 1500. No power. Key stuck. Battery wouldn’t take a charge. Battery replacement fixed the issue. My battery had less than 3000 miles on it and was the best battery they had for my truck. I always buy the best battery because winters are rough here.Went to remote start my truck, no noise or any feedback (2-way remote). So i walk outside to manually start it, no lights flashing when i hit unlock... door wont unlock. I manually unlock it with the key inside the fob, and when i look at the guages, the small red "security?" light is on. I think its the security light, small red led diode looking bulb, bottom right of gauges.
Ok let me break down the key points real quick.
- 2012 Ram 5.7L Hemi
- Battery is 3-4 months old and is a premium battery (forget the brand but it was $270 before my coupon)
- Last drove it 4 days ago
- Remote start installed at Best Buy in December, not a single issue after install... not sure if its related
- Tried to remote start, nothing
- Had to manually open door with key
- No headlight flash or any door chime
- Gauges has small red light lit up for 1/2 a second when i opened door
- Tried to start truck, wouldnt start, key stuck in ignition. Wont turn to off position
- I can not shift the truck out of park into neutral or any gear. Stuck in park.
- I unhooked my Pedal Commander, no fix.
- I unhooked the battery (+ and -) for 10 minutes, did nothing at all
So now im stumped. Key still stuck in my truck, cant shift into any gear. No lights, no radio, no chimes, nothing. Its like the truck is in hibernation mode, or lock down mode. Not sure what to do.
I had an aftermarket remote installed in December. The remote start is the Compustar 4905S kit with 2-way remote (expensive kit). Like i said, ive had zero issues with the remote start since its install.
I have no clue what to even try to do next. I think im going to have to have it towed to a dealer because i am uncomfortable letting my truck sit out front with a key stuck inside. If i cant figure it out in the next couple hours im going to have to have it towed, i am not going to let it sit overnight with a key in it.
Does anyone know what happened or have a similar incident?
