ALPHA OBD HELP
Transparts101
Ohio
I have been looking everywhere for someone that has added the factory remote start to the ram with ALPHA obd. MOPAR # 82214054. Can anyone help? Maybe a step by step or a video?
Ricks Ram
Have you gone to the first page of the alpha OBD thread? All the known working codes plus directions are listed there. You can enable the remote start and program the keys with the alpha tool. It's pretty strait forward once you install everything. I have done a few of them with no issues. I reccomend going to alpha thread and getting all the info you can from the first page. If you have any questions post them there and plenty of people will chime in and guide you through it.
T
Transparts101
Ohio
Sorry, i have been there but didnt see anything about replacing the RF hub, my directions from MOPAR says it has to be done last. Just dont want to mess it up as is was pricey
1500ram12
5.9L Cummins
can you post a link?
If you go to the first page post 1 scroll down until you see my name. Open the Google drive link and I have step by step instructions on how to program the factory remote start and how to program keys
2018 2500 6.4L
Jimmy07
If this is for the 2014 in your signature, and unless you have push button start, you won’t be able to perform the rf hub replace for the new remote start hub. You can TRY it, maybe the developer got the baseline system figured out. Just install everything like the directions say, enable the remote start settings in the known working list, get your PIN, and try to perform the rf hub replace. If it doesn’t work, you can hook your old hub back up and you’ll have to drive it to the dealer and let them do it.
Jimmy07
Edit to what I said above: after you install the parts and enable the remote start settings, your gonna try to program the new fobs FIRST, not replace the hub. Use baseline system to program the fobs, but I doubt you’ll get past that, as that’s where the transfer secret key procedure is supposed to take place, and I don’t think he got that working.
T
Transparts101
Ohio
So I just went to program the brand new fobs and it tells me the fobs are not blank. These came straight from mopar and were not opened. Can anyone help?
T
Transparts101
Ohio
T
Transparts101
Ohio
T
Transparts101
Ohio
joshhhh
