Alpharex luxx 2500 5th gen review
hunterdan
SE PA
2019 classic
I'm contemplating ordering a set of these 2500 5th gen style lights, have watched reviews on YouTube and haven't found much pertaining to these exact lights. I'm currently running knock off OEM projectors, and they're ok, the projector isn't the greatest so the spread isn't the widest. I know there may be issues with the parking light errors and I know I'll probably have to work through them. I'm looking to see if anyone has any output shots of these lights against a wall, both highs and lows. Not really interested in the pro version, but they may give me an idea of what the highs will look like. Screenshot_20230203-063931.png
So I ordered these and will be turning this thread into a review thread for part number 880520.
hunterdan
hunterdan
SE PA
2019 classic
Well, I ordered them and they should be here today. I'm waiting on a set of turn signal sockets since I no longer have my OEM headlights. Will update the post with a review, pics and comparison shots between my current housings and the new ones.
Cableman
Longisland
I wish these lights all came with replaceable hid/led projectors in which they could be pulled from the back cover. Id hate for them to start going after 2 years and no warranty left. My $150 9005 leds are starting to go.
I keep looking at these, morimotos and anzo's.
brianw0048
EcoDiesel
Mine are the pro version, a non-replaceable led is a no-go for me.
55w hid lows
Fahren highs
Low only
Low
Low/fog
Low/fog/high
brianw0048
EcoDiesel
dash cam video from last night.
hunterdan
hunterdan
SE PA
2019 classic
Came in today, got them installed in under 30 minutes. Wiring is a little tight for the turn signal socket adapter, so had a bit of a struggle to get them to lock in. So far, they appear very bright, had one parking light error but even after multiple attempts to recreate it, it hasn't occured again.
As for the pro versions, had a set of the pro housings (dual projector) and did not care for them at all, sold them off. No matter what bulb or hid kit I used, I couldn't get satisfactory results. Full LED projectors have been around for a while and I don't see a ton of people posting up led projector failures from alpharex housings. I'll update with some pictures when it gets dark.
hunterdan
hunterdan
SE PA
2019 classic
Some updates, first night driving had a low beam out warning when using high beams. All bulbs were still illuminated. Upon start up, I get a parking light out errors, but only on start up. It doesn't come on any other time. Output wise, these are pretty good for the money. The cut off is pretty sharp, though it does tend to wash out in the distance, but it still has a solid cutoff line. They are very bright, brighter than my old knock off projector with 50w hid. Good width, good distance. Now that they are aimed pretty decent, the high beam is good. Here are a few pictures of their output on a wall and on the street.
Lows on the street
Highs on the street
Lows only (no fogs)
Highs only
hunterdan
hunterdan
SE PA
2019 classic
Are the cutoff lines nice and straight, no. You're definitely seeing a flare in the cutoff that kicks off high to the passenger side. And kind of tapers down on the driver side. Not exactly the worst thing in the world, but could be annoying if you're OCD and want them to be as straight as possible. The high beam shot seems a bit washed out exposure-wise, it's definitely brighter than what the image is showing. It should be the same as low beam, perhaps a bit brighter since I don't believe these illuminate any other led chips when the highs are engaged.
hunterdan
hunterdan
SE PA
2019 classic
Few more night drives on these, I started getting some bulb out lights, parking lights and left low beam when I hit the high beams. I'm making changes via alfaobd to try and eliminate most if not all the fault codes. My truck originally was equipped with the quad housings and changed it to have the drl enabled, and enabled via the radio. I also set the drl to the turn signals. Plus, all bulbs have been set to LED and hid enabled. The headlamps were also set to quad enabled (from the factory) and I also enabled bi-xenon headlamps. I disabled both settings since this housing only has one "bulb" per side, so that when I trigger the high beams, it's not looking for any activity from the lows. I've also reverted all the DRL settings back to OEM to try and work on the parking lamp out issues. So far, from a quick drive, lows and highs seem to be sorted out. Parking lamps are still TBD.
Output wise, still happy with these. Only thing is, I wish the highs were a bit brighter. I may augment the highs with a set of auxiliary pods behind the grille to give me more distance.
hunterdan
hunterdan
SE PA
2019 classic
Quick update. The lights have been working fantastic, my only issue has been the parking light out warning whenever the headlights (low beams were clicked on/activated the first time or when the truck first started up. Wasn't a big deal since it only chimed once, and never during the use of the turn signals or brake lamps. They've been wired up using the alpharex DRL module and harness that came with them. The other day I ordered the drl wires from @Mpgrimm2 to use the OEM dedicated drl wiring. I had to add these wires and pins to the OEM connector under the fuse box, then run the leads to the housings. The wires were spot on on and labeled, made adding them super easy. Once this was done, I went into alfaobd and changed the drl settings so that they were set to dedicated, led, enabled the left and right dedicated drl, the customer menu, etc. I figured by removing the alpharex harness, I'd lose the startup sequence of the lights, but seems it still functions, at least it does when you remote start at night. I've cleared all the codes that were stored in the BCM and let it rest and reset. Took a few driving cycles for the 8.4 to update and show the setting for the drl. But, on my way to work this evening, everything was updated and it appears the parking light error has gone away. I'm not celebrating 100% yet, but if it truly has disappeared after this modification, I'll be extremely happy. So, this might be an option for those of you running alpharex lights who are plagued with the parking light out errors, and haven't been able to get rid of them. The dedicated drl wires plug right into the bullet connectors on the alpharex housings with drls. Instead of using their harness that draws off the battery, you enable the dedicated drl option via alfaobd.
hunterdan
hunterdan
SE PA
2019 classic
Confirmed after checking and verifying a few times, no more parking light out errors. Might be just the ticket for anyone with alpharex lights and parking light errors.
Devildog8791
Lonoke, AR
I bought a set of these in May of 2021. I had the D/S headlight go out on me yesterday morning when I got to work. I got just over 4 years with the headlight.
I have enjoyed the headlights in the time that I have used them. They have been bright and I have gotten a lot of compliments on them.
I don't know if I am going to go with the same lights now that I need to replace them. I thought about going with the Pro version so I could change the headlight if it goes out, but I don't know what bulb to buy. That's why I went with the Luxx version in the first place so I didn't have to face that dilemma.
I would be interested in more information on the exact process you went through to get rid of the "Parking Light Out" error. I have had that error for some time now and it is kind of annoying. If I buy the same lights again, I'll see how it goes. Maybe things have changed in the four years since I bought mine.
hunterdan
hunterdan
SE PA
2019 classic
I ended up selling these lights after getting a set of pre-production housings from Form Lighting. I never fully got rid of the parking light out errors. They would randomly pop up from time to time. Since going with the forms, have yet to have an error code and the output is better than the alpharex .
Fryekenn
