AlphaRex pro G2 help……
Mcginnis
Forney, TX
Having a problem with my passenger side light after install. There is no cutoff line and just a big hot spot. Wondering if I can fix it myself or no. Installed hids also. Posted 3 pics of both lights on, passengeronly and driver only. You can see in the passenger only there is no cutoff and I have circled in red the hotspot. IMG_2189.jpegIMG_2191.jpegIMG_2190.jpeg
Check how the passenger side bulb is positioned in the housing. Also your passenger side need to come up considerably as the cut off line should match up with each other.
Mcginnis
Mcginnis
Forney, TX
Got home and took it out. Bulb was in correct. Went ahead and turned the bulb to see if that fixes it. I will see when it gets dark.
Arturo Rojas
