amp question??
99ramdyllan
ohio
magnum 5.2
would a 2 channel amp be able to power all 4 of my speakers or would i need a 4 channel amp?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I'd do a 4 channel to have best sound, 2 channel 'would', but I'd go ahead and get a good 4 channel.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
greygoose knows his ****! :D
MADDOG
Living in a Firepit
Definitely go with a 4 channel.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Yeah just run a 4, thats what I put in. I used the 2 for the subwoofer
quietpeen
2021 TRX
Hellcat
yup will be better with a 4 channel amp
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Depends on how you wire the speakers, and if the amp is 2 ohm stable. With out knowing a bit about how to wire a system I'd just get a decent 4 chnl.
olbaid_83
Fort Worth, Texas
seems hotroder got it right.....you have to look at total resistance for each channel and make sure they are all optimal
Born,raised and currently reside in eastern Ohio
1999 quad cab sport 4x4
5.9 Magnum=360CI
A 4 channel is going to give you more flexibility overall...Separate gain setting for front an rear.Separate crossover points front an rear..In my 2nd gen it has larger front door speakers then rears..This is where diff crossover points an separate gain adjustments would come into play for me
