EbbCummins
I have a 2001 ram 2500 Cummins. I’m doing an audio build with 2 3000w subs and 2 2500w amps. When i go to play music the subs barely come on and if i disconnect one amp then the other one will hit a lot better but still nowhere near where they should. Doesn’t matter which one i disconnect, the other will play much better but still seems underpowered. I have a 320amp alternator, 3 batteries, 1/0 gauge wire for all power and ground wires. Power is definitely not the issue, I’m thinking it has to be a ground somewhere. So I’m in the middle of making sure everything has a direct frame ground with 1/0 gauge wire.
