JaKaL3482
This one’s gonna be a long one, stay with me..
So I’ve used the search and couldn’t find what I was looking for. Finally decided to join so I can ask what I really need to know. Brand new to this site.
The truck
2016 ram bighorn with all options besides leather and sunroof.
142k miles
Full delete
Raceme tuner
6 inch lift
37 inch tires
Factory 4 link front and rear
The issue
Heater absolutely sucks
What I’ve done
*Flushed, and back flushed heater core (great flow in and out, little bit of gunk but not terrible.)
*Flushed engine completely and refilled after putting in new coolant resivoir
*Burped the air out of the system
*All hoses roughly same temp when warmed up
*Added an air blocker between intercooler and radiator with 5” hole in center for fan
*New Cummins tstat
This truck has dual climate control, and both sides seem to be doing the same temps. I’ve only had time to check recirc and the blend door actuator behind the glovebox. Both work fine from what I can tell. I pulled the one behind the glovebox off and it moved how it should. Flipped the door from the outside and it went full cycle end to end. I really don’t want to pull the dash to find out it’s something easy I’m overlooking. One time I moved the temp down and back up and it worked until I touched it again. But I can’t get it to do it again.
I’m thinking my blend doors are either broken inside or partially blocked with something, or my heater core is dirty on the outside. But that wouldn’t explain it working once. Seems to be more something electrical
I did a reset on my uconnect and it didn’t change anything.
It seems like with. It sides having the same temps that it’s not the right/left blend doors. But I haven’t pulled the fan and ran an endoscope up there to see yet. Ran out of daylight.
What the actual F am I missing here. I can’t afford to loose more hair…
The truck
142k miles
Full delete
Raceme tuner
6 inch lift
37 inch tires
The issue
What I’ve done
*New Cummins tstat
