Another headlight question (resistor or alfaobd )
tman1112000
Greeneville TN
hemi
Ok guys im still learning the ins and outs of the ram options .so i got some aftermarket projector headlights my drl dont work and get a dash warning manufacturer says i need a resistor pack but i read alfaobd is the right way too fix it . so whats the communities findings and feelings on this . looks like 150 for the alfaobd way and less then 20 on resistor way .
any help would be much appreciated..
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
With alpha, it's not just light fix, it's an investment. You get a easy to toggle options that didn't come on your truck, fix issues like the lamp out problem, not nedding a cheap resister that can possibly overheat she catch fire. You also end up with a very nice obd2 code reader.
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
Installed hid,s on my truck and when cooler in mornings my hid,s would flicker repeatedly till warmed up when below 50 degree,s outside when temps was in 30,s they would random flicker on my trip in to work also I already had Alpha so looking through settings I found a setting for HID,s yes or no turned that setting to yes and they have been flawless since then. Plus found a setting to turn off seat belt warning buzzer I wear seat belt but camping driving through campgrounds, p lot,s belt comes off at check in and the seat belt warning is a pita now no more. The light still lights on dash but no more ding ding ding. I purchased Alpha to reset tire threshold but have found it so much more useful since. plus with Alpha there is no need for me to have to pull out my big scanner to check codes when they show up down the road.
Phirebeard
NW PA
This. Can also change the settings for different gear/ tire sizes. There's a forum section on AlfaOBD that's worth checking out :)
Reticle918
