Steve1500ram
Hi all, firstly sorry for the long post.
I have a 2005 5.7 Hemi with approx 90000 miles which has an intermittent problem with a rough idle and stalling when coming to a stop.
The rough idle only happens when the truck is cold or when first started when warm, after a mile or so it goes away.
The stalling is mainly when cold but does also occasionally happen when warm, I've changed the plugs which seemed to cure it for a short while but now it's happening again.
My check engine light is on with the following codes:
* P0172 Fuel Trim System Rich Bank 1
* P0175 Fuel Trim System Rich Bank 2
* P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
* P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
* P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
* P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
When cleaning the throttle body I found the seal between the resonator box and throttle body is slightly torn, could this possibly be causing an air leak and throwing the codes above? Or should I replace all 4 O2 sensors?
To complicate things the truck also runs on LPG but it seems to make no difference if I switch this off and run it on gas.
Any help would be much appreciated - it's driving me nuts!
Thanks......
Thanks......
