Another RusslRam custom headlight build
3.0 eco
Hey Russ, can you list what components you used? They look fantastic.
Sent from my SM-N950U using Tapatalk
RusslRam
RusslRam
OEM headlights - (fb marketplace)
HID lights - (Amazon)
3” projector - (Amazon)
Projector shroud(g37) - (Amazon)
Fog lights - (Amazon)
Halo switchbacks - (Amazon)
Demon eyes - (Amazon)
Wiring harness - (Retroshop)
Sent from my Pixel using Tapatalk
RusslRam
RusslRam
Checked all the wiring and light alignment. Everything was plug and play and worked with no problems. Forgot to get a good cut off line pic. I got a partial one. Just need to seal them up now onec3dbe5e7d3a8a6369b38bddacf33e732.jpg5d151d0d81331ad8f39cc3a198684c65.jpg76e9c1689a70ccebef06618394f3e6c6.jpg
mondo
Columbia, Pa
2014 2wd express rcsb
Those look great! Keep me in mind if you sell these ones....lol
eaks
Alberta
Ha I spoke with Russ and am first in line.
They look great. When you get them all completed message me with details and we can workout a price.
Great job
OC455
Central NY
I trimmed the shroud for my build to fit tight to the reflector. I looks like I will have to trim the bezel to fit up now. There really isn't a right or wrong way to do this is there?
OC455
Central NY
RusslRam
RusslRam
No right way but several wrong ways. Just take your time and as tedious as it is, trim in small increments. It will take several test fits on and off. By the time you are finished you will be a pro at assembling and disassembling the lights.
RusslRam
RusslRam
Looks great. My only concern is how far back the back of projector sticks out towards the dust cap. Might be a real tight fit with the bulb in. Not sure what set up you are using but with the projectors I have used I have very little space as it is to fit the bulb. I do appreciate and respect the "outside the box" thinking. Keep up the good work.
OC455
Central NY
Thank you. I am trying to limit how much I actually have to trim or.modify any OEM parts to make this work. I figured the shrouds being modified would not cause.me as much of a head ache if I screw amything.up.
Right now, this is the only shroud I modified. I can get another set if I really mess up. Waiting on the HiLens LED high beam projector to arrive.
This pic shows the tail end sticking through. I'm using a Morimoto Mini D2S 4.0e0d46771aa6f89bdcf921da8ea92e255.jpg
OC455
Central NY
This has been about a few hours at a time getting them set and then little trimming here and there. Thank you for the input sir. I like your builds, they look great!
RusslRam
RusslRam
Looks like plenty of clearance. Might have to look into that projector for the next build. Maybe it's just me but I hate how the dust cap is so far off center from the bulb. Be sure to take pictures and maybe start a build thread. That's where I got all my inspiration and information to help with my builds.
OC455
Central NY
Will do, I have a thread started, just haven't updated it like I should be doing.
RusslRam
RusslRam
Sealed them up last night and put them in this morning. Just have to wait until it gets dark so I can get some good pictures. 4e55e4d46984bdf6e15f406987d7b783.jpg9e1c2db68c9c85a81359e3f9b970e39a.jpg497be02f5cd4eaf6074b410a186194da.jpg
RusslRam
RusslRam
Couple of the switch back signals20beda52eb81fe0c3d4130aef9e592b1.jpg3184ace63671da0419a5961ed1dda6dc.jpg
brianw0048
EcoDiesel
once you have the projectors installed - how are they aimed? can they be adjusted after they're sealed back up?
RusslRam
RusslRam
They can't be adjusted clockwise or counter clockwise. They are attached to the original housing so you still have the stock vertical adjustment through the fender.
JustinRam1500
