gibson0822
- Apr 4, 2014
- 3
- 0
- 2003
- Hemi 5.7
I'm new to the whole truck scene and had a fitment question or two. I have a 2003 1500 4wd QCSB with the 5.7 hemi for reference. I was looking at the Rough Country 4 inch lift kit, since I want to level out the front and get a little clearance at the same time. I was also looking at 315/70r17 tires and a 17x9 rim with -6MM offset. If I did my math correctly (which I'm not sure I did and posting for this very reason) The rims/tires should fit and stick out about 1.7 inches from the body. They also should not rub. My current tire size is 265/70r17 on the stock rims. So my questions are: Will this setup work? Is there anything else I need to change/look at because it'll place stress on it? Is my math right in the fact the tire will stick out almost 2 inches? I will have a tuner by that point so I can calibrate my speedo. Thanks for any and all help.
