Antenna question...
anchorsaweigh
With today's technology, you would think that the old fashioned mast antenna would have gone the way of the Do-Do. Why are we all still driving around with these monstrosities sticking out of the fender?
I have tried different stubbys with zero results and I don't want to install the mast again.
Does anyone out there know of a really good (or even decent, for that matter) stubby?
Cheers
Bob
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Bob, absolutely and fully agree. Got to believe the technology is there. Tried a stubby, liked the appearance but in our area could not get the same reception. Sure hope we can find a good solution. Fitz
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I have a stubby(not what SHE said) and works for me in my urban locale. Others have cut the oem down to likeable height
turkeybird56
Central Texas
Well, I got a 2019 with all the stuff built into a roof "pod". Satellite, GPS, antenna, etc, and works well. There is no fender mounted antenna. Not sure if that change would be something U were interested in, just thinking out loud.
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
As long as there are AM radios installed in the vehicles and the mast antenna is the cheapest way to receive AM radio signals, there will be mast antennas.
anchorsaweigh
anchorsaweigh
Who the hell still listens to AM radio?
Truck Fun
Missouri
2021 Classic
I wouldn't object to a shorter model antenna either. Cell phone doesn't have an external antenna; nor does laptop. Surprised AM radio is still around.
turkeybird56
Central Texas
Hmmm, dunno, but I have no antenna but upper pod mounted on roof of truck and listen to AM at times, hmmmm. Just saying......... Not quite sure what is in that pod, but I sure as heck not pulling apart.....
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
Key phrase is "as long as the mast antenna is the cheapest way to receive AM radio". Unless ALL 2019 Ram 1500's have this roof pod.
turkeybird56
Central Texas
Now this is my opinion only, but with all of the 2019's that I looked at, none had a mast antenna, all had antenna pods.
from Truck Trend Reporting:
Moving to the roof, all of the GPS, radio (terrestrial and satellite), and Wi-Fi data are handled by a new “shark fin” antenna, making the Ram 1500 the first pickup to completely do away with the traditional mast antenna. A panoramic sunroof with 10 square feet of glass is now available, and the roof has been formed to flow air seamlessly off the trailing edge and onto the tailgate.
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
Awesome. Way to go Ram. I stand corrected.
Michael Cole
Maryland
I hope to in the near future to build and retro fit a power antenna on my 2015 Laramie. Will purchase the stock antenna base and a Retrosound remote motor antenna, PA-02. An aftermarket non remote power antenna will not fit in fenderwell. Need to remove stock cable base from mounting base and try to retrofit remote cable base on mounting base. Then mount motor in motor bay. Need on/off button switch added as I do not want to run off radio because I do not want it up every time radio is turned on. Have SiriusXM that I use most of the time. Let you know how it works.
Michael Cole
Maryland
Truck has every option you can get except sun roof. Almost $10,000 in options and they still put a stupid whip antenna on the truck. %#@&()*
tourrider
Grumpy
NW PA
CTD 6.7
It comes down to physics. If you want gain at those longer wavelengths, then you need the mast. In urban areas, and when your listening to a 50K watt blowtorch, then you can get away with a stubby, or horizontally embedded element. But in the middle no where, you listen to noise. I listen to AM every morning, and just 50 miles west of Baltimore I still have some trouble until they switch to the daytime non-directional pattern, or I get 10 miles closer in.
2966
niagara
cut oem down and re-attach ball end ..10min your done
muddy12
Indiana
I went with the short flexible parts store antenna.
It works perfectly for me.
However, I had an 82 Chevy K20 that had the antenna embedded in the windshield. Don’t know why they don’t still use those? Great reception, and no external mast.
Aussie-John
Australia
Hemi V8
I have to agree!! Crazy!! Can someone tell me what is the black box on the roof at the rear?? I thought it might be GPS. but that looks to be stuck to windshield
muddy12
Indiana
Most likely the antenna for the xm radio.
