" Anti slip differential "
Ratket
Arizona-
is the anti slip diff the one that is the heila coil?
tncruiser
kingston tn
5.7hemi
i have anti slip and i laid TWO strips in front of my house just to be sure
brianj
6.7CumminsDrvr
The Dude abides………
Georgia
1500's have the clutch type and it requires a friction additive. The HD's use the helical gear type and do not require any additives.
MADDOG
Living in a Firepit
6.4L HEMI
I tested mine yesterday, now that the new engine is broken in.
Ratket
Ratket
Arizona-
I was wondering what a helia coil was. Spell check snafu?
yup.. got to love my auto correct. obviously u guys can smoke the tires on ur 6.4"s.. sadly I can not. I am trying to do it at a elevation of 7k feet so maybe that has something to do with it. :(
RLJ10X
Southern Indiana
Surely, you've turned the traction control off......
That 6.4 with 3.73s ought to melt tires on demand @7000'.
QwikKota
5.7L
I think he meant helical or gear type. Someone said the new 1500's use a gear type now but I can't find definitive information.
MADDOG
Living in a Firepit
6.4L HEMI
Turn off your traction control...
jwheeler
Washington
That is false. Still uses clutches
regularcab2500
Buffalo
5.9 Magnum
I drive around with traction control off. I get wheel hop sometimes after coming out of a turn when i try to give it gas if i dont. Traction control blows.
RLJ10X
Southern Indiana
^if you start having too much "fun", the stability control will spoil the party, even with the TC off.
regularcab2500
Buffalo
5.9 Magnum
Yeah it wont go nuts on dry pavement no matter what...it still leaves streaks mind you lol
