Anybody experience significant rake with Superlift?
MrSoloDolo
Plumas National Forest
The shop had to add rear spacers to elminiate the rake when the Superlift 6” was put on. Has anybody else run in to this problem? Other than that Im very happy with how it turned out and it drives great
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Just be happy you had a shop that recognized the need for additional work to complete a proper installation. So many of these "lift kits" are developed by goobers, for goobers, and are installed by goobers...With none of them having an ounce of engineering experience. Big difference between an engineer and a fabricator...Sometimes, one lacks what the other brings to the table and the project desperately needs.
MrSoloDolo
MrSoloDolo
Well I picked a shop that i have full trust in. Superlift has been around longer than most and I havent heard really any issues pertaining to rake so Id like to hear others experience with the kit
Blstrick55
Everywhere
Did you get the kit with the Bilstein struts in front? If so did they max them out?
kurek
Northwest
Post a picture of your front struts. Including the lower spring seats.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
More details and pictures would be great
ric221
B4 the spacers was the rake in the front or rear. I'm a little confused as to why they had to add spacers
kurek
Northwest
That's why we're trying to get pictures of the front struts. Chances are really good if it's Bilsteins they either installed the lower spring seat upside down, installed it on the wrong notch (stacking lift height on a lift not designed to be stacked) or a magical combination of those two things.
DILLIGAF
Canada
Post front end pics. Somethings not right.
Nick@GotExhaust
Preferred Vendor
SC
I assume you got the lift with the bilstein shocks and they maxed them out in the front. As mentioned post some pics and let us know what shocks you have. that would help us help you.
MrSoloDolo
MrSoloDolo
The shop told me they set the bilsteins at 0 in the front. Its had front spacers since ive owned the truck but I know that they took them out. Ill get some pictures tomorrow when I have light lol. Was on the road all day
Blstrick55
Everywhere
If they’re set to zero then something is definitely wrong with the setup.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
We don’t do super lift often but I believe I remember reading the installation instructions superlift wanted the Bilsteins to be set to 2.8 to achieve their geometry specs. I’ll go back and look if you provide pictures of everything that looks newly installed
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Yes Superlift wants them set to 2.8 (highest ring) so your shop didn’t read the instructions if they set it to 0.
That being said you’re nose high so did they leave something out in the rear ?
MrSoloDolo
MrSoloDolo
Never heard of anyone setting them at 2.8 not even from the company themselves when I talked to one of the Superlift guys about the problem. Nothing was left out of the rear. The shop felt that that the rear coil springs may have been for a different lift but I found out that Superlift uses the same size springs for both 4” and their 6” inch lifts
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
They did the install correctly following the oem guidelines. I shared the instructions above for Bilstein option with super lift so it’s not hear say or made up. It’s clearly stated in their instructions that your shop failed to read that’s my point. All 6” lifts share the same options as their 4” counterparts the only difference is the front spacer and preload spacer options. These trucks react weird and are very sensitive to small changes with how springs are clocked etc. I’m not attacking you or the shop we are all human and all make mistakes that are easily overlooked.
MrSoloDolo
MrSoloDolo
That makes sense. The truck has to go in anyway next week for retorque and getting my UCAs installed so Ill let them know. As the long as it wont cause any issues though i might just keep it as is. Thank you for the information
Blstrick55
Everywhere
Isn’t the silver thing under the strut spacer a preload spacer? If so that shouldn’t be there with the Bilsteins. They should use the adjustable clip on the Bilsteins to raise height instead of the preload spacer + strut spacer combo.
