- Nov 3, 2011
- 8,366
- 7,529
- Location
- Houston, Texas
- 2017
- Hemi 5.7
Wow that's crazy, they shipped mine the same day.
Mine came in from Amazon but the driver side won't stay locked into it's tab in the bracket. The plastic is so thin it's not strong enough to hold the fog light in it. Thinking about returning. They are bright and look good but can't aim the driverside at all.
Mine were a little loose too so I removed the bracket, then installed a small thin cable tie around the holes as shown in the pics below, then reinstalled the bracket. It tightened mine up and I haven’t had any issues. I figured I would try the same fix that’s used for the oem fog lights since these have the same bracket design. Might be worth a try for yours.
I just installed these! I'm my opinion, they look great. The light output is pretty good. I like the way the fog's DRL square up with headlight's DRLs. Installation took about 30 minutes. I had to connect the DRL wires from each fog together then I added another wire from there to the existing DRL tap on the fuse box (#66) where the ARex DRLs are connected.Have any of you tried these, been looking at both styles, kind of like the drl on these, can use for turn signal if you wanted to. Reviews say they are super bright and might look good with the alpharex headlights I have. Also these are between $60 a set and $120 depending where you buy them.
I can shed some light on this. The fogs in my 2014 have a smaller hole that mounts in that bracket. Factory Fogs from a 2018 have a hole at least twice as large as my original 2014 brackets. What you pictured appears to be remedy for older trucks with loose fitment.
I have a set on order from www.carid.com under a different brand name …
https://www.carid.com/2017-ram-1500-fog-lights/lumen-fog-lights-2541768786.html
If you ordered the pre-cut to fit pieces you may be disappointed in their coverage. I recommend getting a piece of Lamin-X large enough to cut your own.So Z-OFFROAD responded to my query. This was their response:
"Hi Potatomafia, thank you for your message. This is Jessica from Z-OFFROAD. I could tell you that the light you received is New Stock after checking your pics. And now all the stock we sell in amazon is new stock with new bracket. A month ago, we got product feedback from some customers and noticed that a few models may get some issues when installing these lights. So we improved the tap part to make it tighter when installing the lights. (Check the attachment , please). There is no big difference between the new or old bracket besides the tap part.
Have you installed the light on your ram? and please feel free to contact us again if you need any installation when installing them.
I appreciate your time."
This is the pic she sent back:
I can't really tell what they changed, to be honest. The bracket fits OK I guess. It has a little slop in it but I think using the zip tie method earlier in this thread will eliminate the slop. I was hoping it would have the piece of metal riveted to the bracket like on @kad's lights.
I'm going to wait to install these until my Lamin-X film gets delivered. The film should be here by the 4th.
not overly impressed but the look good... I had to adjust them all the way till the nut almost comes off the adjustment screw... they're a little loose...what's the verdict on these @MCMLXIX ?
