Anyone know how to remove haze from headlights?
Big Boi
S. Fla
So I'm a dummy... I left the dust caps off the back of my quad headlights after installing HID'S over a year ago. I now have a bad case of haze in the direct path of the light throw. I'm guessing moisture built up inside and as i turned on the hids it etched the lenses causing haze. Never enough to show water droplets, but enough to fog them up from time to time.
Anyone have any ideas how to polish out the haze? I'm going to repaint the shrouds so I want to remove the haze at the same time.
charonblk07
Calgary, Ab
F1-A forged 349ci
If you're planning on opening them up in the future then either wet sand them with a high grit paper or pick up a headlight restoration kit and polish the haze away.
RyanJM
Houston
2014 Express RC Black Edition
+1 the only way I can see that coming out it wet sand and polish.
WhiteExpress
Midland, TX
Nick @ Adam's said something really profound...
I don't recall what it was, but basically, start with the least invasive path first.
Get some Meguire's plastic polish and try that. It's a great product, very NON abrasive.
If that doesn't work, try their plastic cleaner first, it's got some very mild abrasives that the polish will clear up.
If and only iff (IFF) that doesn't work, consider some 3,000+ grit paper.
Chances are, at that point, you'll never have a hard time getting it clear again.
swanny297
Apply toothpaste with a dry cloth and wipe off with a damp cloth
chris*1989
Just grab a headlight resto kit from a parts store. If it doesn't work, the rest of the gimmicks most likely won't either. Get some new ones!
2711
HEMI 5.7
Did the heat from the HID bulbs melt the plastic a bit?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I hope you guys realize that the inside of the lights are NOT clear coated......and most options listed will not work for this.
TexasNav
Thats what I was thinking but I dont know much in the realm of headlights....other than that stock sucks....as soon as I can convince the money holder to let me get some Retros I will.
Big Boi
Big Boi
S. Fla
That's what I was thinking JJ. Sux though
