Anyone running a Powerwire?
Budakane
Northern VA
345ci Hemi
Is anyone on here running a powerwire and is decently modded? I keep getting a code, that my truck is runing lean, and I am leaning twds the resistor. ANyone else having this issue?
Budakane
Budakane
Northern VA
345ci Hemi
Racking my brain here, I havent a cluw why my truck is running lean.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Do you have an air/fuel gauge to read your actual air/fuel, or are you just going off a lean code? Lean codes can be caused by many things. While I never saw any gains from the powerwire, I don't see how it would cause a lean code. If anything the cooler IAT temp reading should make it add more fuel, not less.
rgroome7
Bradley IL
My truck was running lean recently, ended up just being bad fuel. Hopefully its as simple as that for you
89gtcs
Take the power wire out, clear the code, unhook the battery for 30 min to let the PCM's adaptive learning reset, and then go for a spin. See if it comes back.
ST-8
When I first read the title I thought it said power glide. Long day!!
