1500ram12
- Jan 23, 2012
- 5,487
- 2,432
- 2005
- 5.9L Cummins
You adjust it from under hood, there is hole on side above lights. No need to remove the lights to adjust. Put a Phillips in hole where you can see the adjuster and turn until you see lights move, is quick and easy, nothing to remove.
Just went back out and tried with a #3 Phillips like Jimmy07 mention and was able to adjust it. I was looking for the actual head of the bolt/screw to adjust with. This is my first pair of "aftermarket" (other than tyc) headlights so I'm used to dealing a factory adjustment.
