Are Billstein 5100's the solution to this problem?
macmongrel
Alaska
#1 is the front...# 2 is the Rear....
SHould I get new shocks?
Musclemckeester
Houston, TX
n/a
n/a
Hmm, I thought the Rough Country kits made the truck sit nearly level.
I got Bilsteins because mine wasn't sitting level after the lift. Regrets? Nope.
macmongrel
macmongrel
Alaska
I won't need new springs if I get new front Shocks will i?
Musclemckeester
Houston, TX
n/a
n/a
The shocks are mounted within the springs, but come apart. You don't need new springs.
Catchin Zs
Wilmington, NC
So basically the Bilsteins will give more lift in the front on no matter what type of kit unless it has coilovers?
sphincter
Basically, yes. Bilsteins will provide additional lift to any kit that utilizes the factory shocks.
Catchin Zs
Wilmington, NC
I have Bilsteins right now front and rear without a lift kit. If I got a lift and wanted to keep Bilsteins, I'd have to find the correct rear shocks, but could keep the lift struts, right?
Thor09
Northern PA
Yes, you could keep your front Bilsteins on. Most lift companies supply the rear shocks with the lift. So you wouldn't have to look for any rear ones unless you didn't like the ones that come with whatever lift you get.
quietpeen
2021 TRX
Hellcat
so you gonna get some some?
macmongrel
macmongrel
Alaska
I think I will as soon as I sell my old tires
Timkll
