Whitd5
Just starting a thread to show my audio build. Enjoying the project for now and can’t wait to get it all finished up.
That sub is a perfect match for that enclosure and its available volume. May consider adding some butyl deadener to the inside of the enclosures plastic tub.
Very nice job. Let us know how the Precision Power speakers sound? Are those flax paper cones?
You can get great staging with the tweeters in the sail panels. Just be aware that they will be the closest to you and could potentially overpower everything else.
I’m assuming you’re using the PPI passive crossovers? If so, see if there is a way to drop the tweeter level. Many crossovers have a switch or a secondary screw post that drops the output by a few DBs.
Another option is to try and get the tweeters in the dash next to the mids. That all depends on how big the mids actually are.
Non Amped system needs 4) 47 phm 5 watt resistors and you should be fine. If you have an upgraded system like Alpine, use this. https://pac-audio.com/catalog/amppro-amplifier-interfaces/ap4-ch41How did you wire the amp to the head unit? I've heard a few mixed things from some local shops like the 8.4 head units need resistance which has been making me procrastinate putting in my amp lol
mine is non alpine 8.4 u connect. using lc21 tapped into rear speakers for sub should work? not adding amp for highs.
