Auto Door Locks
Kiska
Calgary
2013 Ram crew cab ...Very annoying feature, step out of the truck for a few seconds and ......"CLICK". I've tried every solution posted and nothing seems to work. There has to be at least one wire I can snip to disable the time delay without affecting the fob or door switch. What else out there is worth a try?
Jimmy07
What exactly is happening? Do you have push button start?
MADDOG
Living in a Firepit
So is your truck equipped with the remote access feature?
JPT
NY
2015 Big Horn
You have to have an aftermarket alarm like a Viper. If so, you can get that turned off.
The only auto lock I have from the factory is the lock when reaching a certain speed, not when the truck is stopped/off.
Puffin
W. Pa.
6.7L Cummins Diesel
Auto locking on my 2014 Ram Longhorn Laramie, started locking seconds after unlocking and acting up with various LOCKING AND UNLOCKING symptoms. uNDERer the dash I can hear a clicking sound and when it first went bad, under warranty ram replaced a control module under dash value was 294. or such. NOW it is doing same again. Locks, quickly, have to use key fob to unlock constantly all doors, sometimes remote start is screwed up..ANY FIX FOR THIS LIKIE BATTERY DISCONNECT..
RamCares
n/a
n/a
Hi Puffin,
we are sorry to hear that you have been experiencing this concern with your door locks. Have you had the opportunity to have your dealer address this concern? Please send us a private message if you would like some additional assistance.
Alex
Ram Social Care Specialist
