Auto to manual swap
Jerry 601
Ms
Hi guys new here I have questions about doing a auto to manual swap I have 88 dodge w350 with a automatic I also have a 85 dodge d350 with a manual I bought a NP435 dodge 4x4 trans was wanting to use the clutch/clutch linkages and brake pedal from the 85 will all this work and I forgot to mention the transfer case is a np 205 will it bolt up to the np435
crazzywolfie
under the truck
might need to cut up the 85 and weld stuff onto the 88 to do that swap. pretty sure the 85 should have mechanical clutch linkage and the cab itself has differences to the floor because of the clutch linkage.
