Auto trans stuck in low no other issues
joeh55
My 2001 Ram on Xmas day is stuck in low gear, What is the issue, btw 240,000 miles filter changed once, I'm told shift solenoid replacement. thks. Joe in KS.
dapepper9
Iowa/Nebraska Border
5.9L V8
I would start with fluid and filter change, band adjustment, and replacing the solenoids. Cascade transmission parts sells a good solenoid kit. Would also delete the check valve in the cooler line.
If this doesn't help, you're probably looking at valvebody replacement at best but possibly the entire trans
