Automatic Climate Control
ram-head
Arkansas
Has anyone explored the feasibility of adding automatic climate control to a truck that doesn't have it? I have a '15 Big Horn with the 8.4A. It doesn't have dual climate, either. Would all that need to be added as well?
Tach_tech
5.7L HEMI
You can only have the automatic temp control with dual zone. There is no auto without dual zone. It could likely be done, but you would likely need everything from the auto control system including HVAC housing assembly and actuators, likely the wiring harness, temp and humidity sensors, control unit and centre stack trim and the list goes on. I don't see it being remotely feasible unless you had a donor truck.
joshhhh
