Aux Gas Tank
avolnek
2015 Ram 2500 CCLB
Has anyone ever installed an aux fuel tank for gas pickups? I have done some for diesel trucks and plumbed right into the existing fuel necks of stock tank to keep stock tank full... was just curious if this can be done and done safely/legally with gasoline instead of diesel...
Dubstep Shep
Houston
2014 R/T
If it's been done safely with diesel, I don't see why gasoline would change anything.
Just make sure your evap system doesn't freak out
A
avolnek
2015 Ram 2500 CCLB
I believe that with gas you can't run the gravity fed system. My understanding is that it requires the use of a pump to pump the fuel... not 100% sure on that...
Dubstep Shep
Houston
2014 R/T
Sure, you need a pump to get the fuel from the tank to the injectors, but a gravity feed into the tank shouldn't be an issue
A
avolnek
2015 Ram 2500 CCLB
I am aware there is a pump from the stock tank to the injectors...
I am stating that I am under the impression that I cannot legally gravity feed from an aux tank to the stock tank...
Dubstep Shep
Houston
2014 R/T
Oh, I can't comment on the legality of it, I'm no lawyer. I wouldn't think the law would be any different though.
Broke pilot
Conroe, TX
6.4L
If you're just looking for extra fuel, check out Titan fuel tanks. I think they're working on a new ram tank
bighorn2500
2015 2500 ram bighorn
6.4 hemi
Ati brand tanks are built to requirments for diesel or gas and there no that high in price.
Steve Holtz
