Aux Reverse Lighting - Let's see your setup!
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Tailgate light bar and led reverse bulbs. No camera shots, my bad
blackbetty14
CT
Hemi 5.7 VVT/Etorque
It’s in the thread I linked, but requires some drilling
Yea that hitch is like 1/4" plate.... some thick metal to drill! Looks good tho!
Deepc6
Long Island
Hemi 5.7 Etorque
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Very nice, I may have missed it but do you have a link for the product you're using?
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
so I asked this question in another section with no answer so i'll ask here. Can the factory trailer be removed from the mount to access it better? I wired my lights to that with some wire taps and now I had a bad or loose connection and my lights are so dim I cant see them. i can move the wire tap and they come on bright as ever but go away after some driving.
Ramm5.7
So Cal
Here is a pic. New phone so still trying to figure out how to add link
NCRaineman
NC
2019 1500 Classic
This is what I want to do but I lack the tools and the talent. Any body within 60 miles of Dahlonega, Ga that can help me??
Any local shop that does body work could set that up for you. Probably wouldn't cost that much either, so long as you provided the lights. Cutting the holes and mounting things up would take maybe 2 hours labor.
McBroom
Denison Tx
Hemi 6.4L
Redo the wire tap or it’s a bad ground
Blue Streak Pearl off-road package
David Skinner
Oswego
here's my red 1500 with custom brackets, that thing throws out some serious light! and my 2500, cut the bumper and put a bit smaller, more reasonable lights in.
Do you like the lights being higher up? I have wondered if the lower down, under bumper provide enough light up higher on a trailer.
Hemi395
Cape Cod MA
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
