back pressure POP?
stevens
2015 Dodge Ram sport 4x4 crew
so something weird happened today....i got a flow master....thunder series? i think? it has a super 10 on it...annywayss....i was doing a burnout and i eventually let off the break and let the truck go...it was going then all of a sudden i heard a big "pop" SOUND. and lost like all power..like my shift gage went all the way down then right back up and i gained power...it honestly felt like 1second it lost power then gained it all back..whats all that about?
perk7089
Cummins 6.7
Sounds like a backfire to me but I'm not a mechanic
Sent from my XT1080 using Tapatalk
Rustycowl69
2001 ram 3500
V10
if it is a backfire, you might look to make sure you don't have an exhaust leak at the heads to exh. manifolds, or exh manifolds to head pipe connections. If it is a backfire in the muffler, you might find it half again bigger than it was. LOL.
stevens
stevens
***** yeah it was a pretty loud POP...anything els i should look at? will i notice anything if i look?
hemi1282
Arkansas
2016 Ram Tradesman
I wouldn't mind seeing a good ole burnout with that exhuast did u video it?
7777xm
Covington, GA
Sounds like you experienced the RAM exhaust fart. It extremely amplified when aftermarket exhaust is used. I've noticed it happens only during heavy to WOT and around shift points, usually 1st to 2nd.
Sent from my SM-N930T using Tapatalk
