Backspacing Expertise Required
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Good morning guys. I am going to be installing 20x10 Fuel Vapor (D560) wheels (5x5.5 BP) (-18 mm) wrapped in the 37X13.50R20 Toyo R/T tires here soon. I'm puttin a 6" suspension lift, 1.5" body and Bils set at 2.1. I am wondering if I am going to have any rubbing issues with that setup? I don't think I should but figured I'd check with you guys on here since you have helped me so much as it is. Thanks in advance!
Adam
Rzrman328
The treeline
I'm no expert in back spacing by any means ha...but mine are a -44 and they did rub a bit. Nothing a lil cutting couldn't fix but then again I am only on a 6" lift.
I think you'll be fine with the bl and bils on top of the 6".
Again..my opinion.
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Again..my opinion.
Thanks Rzrman. :)
Adam
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
With the Bilsteins and body lift on there you won't have any issues running that setup. If you hit a hard bump while turning sharp then you may rub the plastic fender liner. But that would be about it.
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Sounds great man, thanks a lot. I just wanted to make sure before I go and order these that everything would fit fine... Especially since I'm doing the install. Thanks again, gentlemen!
Adam
