Backup Camera Missing Lines
John Wiles
Oklahoma
Cummins
i just purchased a used 2014 2500 RAM with Cargo and Backup Cameras. I don’t have the lines in my backup camera. I have a 8.4N Radio. There is no place (that I can find) to turn them on/off. Is there a fuse? Possible Software Upgrade? I currently have software version 17.11.07. Thanks in advanced for any help
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Do you know if the truck came from the factory with the 8.4 radio.?
Do you currently have the backup and cargo cams displayed on the radio or is the backup cam on the mirror and cargo cam on the radio?
If it's the first option, be aware that only v17.11.07 supports both cameras on the radio at the same time.
Edit: the backup camera gridlines are enabled by a setting in the BCM and there's also a Customer Settings Menu feature in the BCM to have the option show up on the radio.
Or there is a missing/disconnected signal wire between the BCM C5/E -45 and the camera.
M² Mods.
J
John Wiles
Oklahoma
Cummins
I believe everything is factory. I did wiring mods today to move the rear view camera into the radio. Swapped the input wires so that both cameras are correct with the soft touch buttons
How do you access the BCM customer settings menu?
Thanks
Mpgrimm2
Preferred Vendor
SC
5.7L
denning
