Backup Camera
sammar
V8 Magnum
Hi all,
I installed a Laviay Wireless Android Auto Screen in my 2013 Ram 1500. The screen works great and nice to have Android Auto. It came with a rear backup camera. I installed that and the camera works. I connected the trigger wire to the positive wire on the left reverse light. When I put it in reverse the backup camera is not triggered. Has anyone else had this with an aftermarket Reverse Camera?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Hi all,
Are you sure that is the proper way to wire it? Some use a CANBUS signal to determine when the vehicle is in reverse. There also may be a setting in the radio for an aftermarket vs OEM camera that needs to be flipped.
S
sammar
V8 Magnum
Hey thanks for the response. I followed the instructions. If I select the camera manually it works. If I put the vehicle in reverse it does not come on. The stock radio is still installed I did not remove it this is just an addon. This is supposed to work on any vehicle by connecting to the Reverse tail light. The wire provided is just that length.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Do you have the install insructions that you can post or link to?
aszumilo
Navy Badge
Las Vegas
Sounds like your new radio is not getting the signal that the truck is in reverse.
wrench78
Air Force Law Enforcement
SE PA
2022 2500 Laramie
6.4L
Hi all,
Just a thought. You talk about the trigger wire to the reverse light. Did you hook up a ground wire? If you did, and you are sure the trigger wire is correct, Try a different ground.
S
sammar
V8 Magnum
There is no ground wire. There is the trigger wire and the wire that hooks to the main unit
markabby
Monticello, Kentucky
2020 Limited
just a dumb question: are you positive you're on the correct back up/reverse light wire and making a good connection?
or, lock the brakes via the e-brake, truck in reverse, and connect 12 volts to the wire and see if that triggers the camera.
S
sammar
V8 Magnum
I have tested the wire yes with my wife on the brake and truck in R the light lights up and i know the purple wire is positive i used a tester
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I do yea sorry for the time lag been busy
Here's a thought. I'd like you to disconnect that "trigger" wire completely and see if you still can view the camera (not in reverse). I'm thinking that is not in fact a trigger wire for reverse and is instead just a wire that sends power to the camera only when in reverse so it won't drain the battery. If so, this would mean there is likely a software setting to get this working and your wiring is not at fault.
S
sammar
V8 Magnum
the camera works with out the wire. It is powered from the main unit.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Well darn...it could still be a setting though that says something about reverse signaling. Where there any other pictures of wiring included in the instructions? Do you have a link to what you purchased?
diymirage
Banned
you got a 7 pin trailer plug on there, correct?
just for fun, push that lil wire into the reverse light pole of that plug
(that will ensure you got a solid 12v)
got a link to the camera you got?
id like to look at some of thier pictures
i know i had issues with one of mine, and it turned out i needed a dedicated ground to it
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That's where I would have tapped too...
S
sammar
V8 Magnum
There were no other instructions for install no. I wish lol
This is what I purchased
S
sammar
V8 Magnum
I do have a 7 pin plug yes never thought of tapping in there hmmm
this is what i purchased
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Upon seeing this isn't a radio and not getting any signal from the CANBUS, I'm thinking it just has a setting that needs to be changed in one of the menus if you know the signal wire is good.
NoTreadWear
Louisiana
Disconnect power from head unit and allow you reverse light switch be the only 12 v powering the camera
Jantelaw
